[fdo-trac] #443: PostGIS defect : Only 1 geometry column of a table can be used
FDO trac_fdo at osgeo.org
Thu Dec 11 14:58:18 EST 2008
   Reporter:  mwtoews           |       Owner:  mloskot
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:  3.4.0
  Component:  PostGIS Provider  |     Version:  3.2.0
   Severity:  3                 |    Keywords:
External_id:                    |
 I have a table that defines two geometry columns for georeferenced and
 unreferenced site-plan coordinates:
 CREATE TABLE fdb.area(
   gid serial NOT NULL,
   unref geometry, -- SELECT
 AddGeometryColumn('fdb','area','unref',-1,'POLYGON',2)
   georef geometry, -- SELECT
 AddGeometryColumn('fdb','area','georef',4326,'POLYGON',2)
 and I've add this into geometry_columns:
  f_table_catalog | f_table_schema | f_table_name | f_geometry_column |
 coord_dimension | srid |  type
                  | fdo            | area         | georef            |
 2 | 4326 | POLYGON
                  | fdo            | area         | unref             |
 2 |   -1 | POLYGON
 (2 rows)
 However, when I try to pull the data up in AutoCAD Map 3D 2008, I only see
 one "area" with SRID -1, and I don't see both combinations (as I do with
 QGIS).
Ticket URL: <http://trac.osgeo.org/fdo/ticket/443>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
