[fdo-trac] #210: Filename Case Dependancy on SHP Provider
FDO trac_fdo at osgeo.org
Sat Jan 5 06:32:17 EST 2008
   Reporter:  crispinatime  |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  minor         |   Milestone:  3.3.0
  Component:  SHP Provider  |     Version:  3.2.0
   Severity:  3             |    Keywords:
External_id:                |
 There is (seems to be) a filename case dependancy in the SHP provider
 whereby if the associated DBF file has a different case in the name or
 extension the schema information in the DBF is not recognised.
 There are many tools that create SHP/DBF as a 'standard' GIS interchange
 format and several create upper-case DBF files and lowercase SHP leading
 to confusion and additional filename/batch processing before FDO can be
 used.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/210>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
