[fdo-trac] #215: SDF scrollable reader gives null values higher weight than non null values
FDO trac_fdo at osgeo.org
Wed Jan 9 15:09:15 EST 2008
   Reporter:  badreddinekaroui  |       Owner:  Badreddine Karoui
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:  3.3.0
  Component:  FDO API           |     Version:  3.2.0
   Severity:  3                 |    Keywords:
External_id:  1000636           |
 When ordering the result using a descending option, the SDF provider
 returns the null values before returninhg the non-null values. It should
 be the other way around. This is very apparent when the reader is ordered
 using multiple properties with the same ordering option, the result is not
 ordered or only partly ordered.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/215>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
