[fdo-trac] #219: "Default" must be untranslated in ShpMessage.dll
FDO trac_fdo at osgeo.org
Thu Jan 10 17:40:50 EST 2008
   Reporter:  danstoica     |       Owner:  danstoica
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.3.0
  Component:  SHP Provider  |     Version:  3.3.0
   Severity:  2             |    Keywords:
External_id:  938072        |
 This is an FDO defect. It will also cause failures when opening a Map DWG
 one language OS which was saved on under a different language OS where the
 Map contains a gis layer referencing one or more SHP files. The same issue
 will break transferring MG packages referencing SHP features sources
 accross machines running different languages.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/219>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
