[fdo-trac] #221: Set the default resolution of wms provider to 256*256
FDO trac_fdo at osgeo.org
Sun Jan 13 03:06:14 EST 2008
   Reporter:  leodai        |       Owner:  leodai
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.3.0
  Component:  WMS Provider  |     Version:  3.2.0
   Severity:  3             |    Keywords:
External_id:                |
 Some WMS servers don't support 1024 pixel size. So if you execute a select
 command which doesn't have Identifier like "Resample" or "Clip", it will
 use the default resolution to query the data. And then the server may
 return a exception to the client. But mostly the select command without
 Identifier is just used for getting some query information like extents
 and bands. In another word, high resolution is no useness in this step.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/221>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
