[fdo-trac] #228: MySQL Defect : Can't retreive tablename in joined
query
trac_fdo at osgeo.org
Fri Jan 18 08:30:27 EST 2008
#228: MySQL Defect : Can't retreive tablename in joined query
Reporter: bscott | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: MySQL Provider | Version: 3.2.0
Severity: 4 | Keywords:
External_id: |
I use FdoISQLCommand to execute joined query in fdo provider that support
SQLCommand.
Typical query:
Select table1.column1,table2.column1 from table1,table2 where table1.key
= table2.key
In FdoMySQL the query execute properly but when a retreive the result
using
FdoISQLDataReader::GetColumnName(index)
i only get the column name without the tablename
So there are no ways to distinguish between table1.column1 and
table2.column1
because GetColumnName only return column1.
either GetColumnName should return tableName.columnName
or a new function GetTableName should be implemented
Orest Comment:
You could go ahead a create a ticket for this one as well and we can
consider an approach around GetColumnName. A GetTableName approach may not
always make sense in all cases. E.g. 'select table1.column1 +
table2.column2 from table1, table2, ...'.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/228>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
