[fdo-trac] #229: MySQL provider should use the native MySQL `
instead of "
trac_fdo at osgeo.org
Fri Jan 18 08:37:40 EST 2008
#229: MySQL provider should use the native MySQL ` instead of "
Reporter: bscott | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: FDO API | Version: 3.2.0
Severity: 3 | Keywords:
External_id: |
I'm trying to do that type of sql statement : "select Count(1) from POINT
where NOT POINT.KEY_1 NULL" Using the MySQL provider
The MySQL provider push that query to MySQL
select Count(1) FROM "point" H WHERE NOT H."key_1" IS NULL
and it does not work
I have used this fonction
FdoComputedIdentifier::Create("Count(1)",FdoExpression::Parse("Count(1)"));
This thing throw me an exception:
RDBMS: You have an error in your SQL syntax; check the manual that
corresponds to your MySQL server version for the right syntax to use near
'Count(1) FROM "fdomysqladsk"."point" H WHERE ( NOT ( H."key_1" IS NULL
) ' at line 1
i've tried this syntax inside MySql and it throws me the same error.
But if we replace all " by ` it works
wrong : select Count(1) FROM "fdomysqladsk"."point" H WHERE NOT
H."key_1" IS NULL
good: select Count(1) FROM `fdomysqladsk`.`point` H WHERE NOT H.`key_1`
IS NULL
Ticket URL: <http://trac.osgeo.org/fdo/ticket/229>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
