[fdo-trac] #243: SDF: support making value constraints more restrictive
FDO trac_fdo at osgeo.org
Mon Jan 28 13:42:53 EST 2008
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  enhancement    |      Status:  new
   Priority:  minor          |   Milestone:  3.3.0
  Component:  SDF Provider   |     Version:  3.3.0
   Severity:  2              |    Keywords:  SDF Apply Schema Value Constraint restrictive
External_id:                 |
 The SDF Provider's FdoIApplySchema currently disallows the following for
 data properties with values:
     - Add a new constraint
     - Modify an existing constraint by making it more restrictive.
 Under this enhancement, the above 2 types of modifications will be
 supported. It is possible for existing property values to violate the
 new/modified constraint. All data values will be checked. If any do
 violate the constraint, and exception will be thrown similar to:
     Cannot modify constraint for property
 'constraints:CDataBaseClass.StringList';
     existing data value 'close' violates new constraint
Ticket URL: <http://trac.osgeo.org/fdo/ticket/243>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
