[fdo-trac] #243: SDF: support making value constraints more
restrictive
trac_fdo at osgeo.org
Mon Jan 28 15:00:04 EST 2008
#243: SDF: support making value constraints more restrictive
Reporter: brentrobinson | Owner: brentrobinson
Type: enhancement | Status: closed
Priority: minor | Milestone: 3.3.0
Component: SDF Provider | Version: 3.3.0
Severity: 2 | Resolution: fixed
Keywords: SDF Apply Schema Value Constraint restrictive | External_id:
Changes (by brentrobinson):
* status: assigned => closed
* resolution: => fixed
Comment:
Revision: 3744
Author: brentrobinson
Date: 2:59:07 PM, Monday, January 28, 2008
Message:
Ticket#243: SDF: allow making value constraints more restrictive.
Modified : /trunk/Fdo/UnitTest/SchemaTest.cpp
Modified : /trunk/Fdo/UnitTest/SchemaTest.h
Modified : /trunk/Fdo/Unmanaged/Inc/Common/Compare.h
Modified : /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h
Modified : /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraint.h
Modified :
/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h
Modified :
/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintRange.h
Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp
Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp
Modified :
/trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp
Modified :
/trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp
Modified : /trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc
Modified : /trunk/Providers/SDF/Src/Provider/SdfSchemaMergeContext.cpp
Modified : /trunk/Providers/SDF/Src/Provider/SdfSchemaMergeContext.h
Modified : /trunk/Providers/SDF/Src/UnitTest/ConstraintsTest.cpp
Modified : /trunk/Providers/SDF/Src/UnitTest/ConstraintsTest.h
Modified : /trunk/Utilities/TestCommon/Inc/TestCommonConstraints.h
Modified : /trunk/Utilities/TestCommon/Src/TestCommonConstraints.cpp
Modified : /trunk/Utilities/TestCommon/Src/TestCommonMiscUtil.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/243#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
