[fdo-trac] #354: PostGIS Defect : cursor name conflict make provider crash
FDO trac_fdo at osgeo.org
Wed Jul 2 12:56:22 EDT 2008
 Reporter:  bscott            |         Owner:  mloskot
     Type:  defect            |        Status:  new
 Priority:  blocker           |     Milestone:  3.4.0
Component:  PostGIS Provider  |       Version:  3.2.0
 Severity:  1                 |    Resolution:
 Keywords:                    |   External_id:
Comment (by jbirch):
 This problem was also addressed in #116 by adding more granularity to the
 time measure.  Did this get reverted when the dependancy on the boost time
 library was removed, or are you seeing conflicts at the microsecond level?
 Regardless, the potential for conflict still exists regardless of the time
 interval used.
 What are you planning to use as the random seed?  Is there some kind of
 identifier available that is already unique for each query?
Ticket URL: <https://trac.osgeo.org/fdo/ticket/354#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
