[fdo-trac] #272: SDF: Unfriendly message when aggregate function passed to FdoISelect.
FDO trac_fdo at osgeo.org
Tue Mar 11 13:25:53 EDT 2008
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  defect         |      Status:  new
   Priority:  minor          |   Milestone:
  Component:  FDO API        |     Version:
   Severity:  3              |    Keywords:  SDF aggregate function FdoISelect FdoISelectAggregates
External_id:                 |
 The SDF provider FdoISelect implementation does not support aggregate
 functions. Aggregates must be evaluated using the FdoISelectAggregates
 command.
 However, when the select list for FdoISelect contains a computed property
 on a aggregate function, a "vector subscript out of range" message is
 issued when the application tries to retrieve values for the property.
 Under this ticket, the behaviour will be changed to issue a more
 informative message.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/272>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
