[fdo-trac] #343: OGR select problem
trac_fdo at osgeo.org
Sat May 17 13:03:14 EDT 2008
Reporter: ksgeograf | Owner: traianstanev
Type: defect | Status: new
Priority: minor | Milestone: 3.4.0
Component: OGR Provider | Version: 3.3.1
Severity: 3 | Resolution:
Keywords: | External_id:
Comment (by traianstanev):
Hi Kenneth,
I reviewed the patch. It looks fine, except for one problem. Since you are
handling all spatial operations (not just intersects), you need to zero
out the OGR BBOX filter in case of operations like Disjoint, where the OGR
BBOX intersection will return the opposite of what you want for the post-
process FDO filter.
I can fix this when I apply the patch next week.
Traian
Ticket URL: <https://trac.osgeo.org/fdo/ticket/343#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
