[fdo-trac] #344: PostGIS Defect : selecting features does not work
	when primary index is not the first index ceated
    trac_fdo at osgeo.org
    Mon May 19 03:03:17 EDT 2008
#344: PostGIS Defect : selecting features does not work when primary index is not
   Reporter:  bscott            |       Owner:  mloskot
       Type:  defect            |      Status:  new
   Priority:  blocker           |   Milestone:  3.4.0
  Component:  PostGIS Provider  |     Version:  3.2.0
   Severity:  1                 |    Keywords:
External_id:                    |
 If the first index created on a PostGIS table is not the primary one, it's
 not possible to select a feature in Mapguide. To reproduce you just have
 to drop the primary index and recreate it, thus this index become created
 after the spatial index and selecting won't work anymore. To reanable it,
 just drop the spatial index and recreate it ...
 Another effect of this defect, is in mapguide studio when you created a
 new PostGIS data connection we have the ability to preview all the tables.
 All the unselectable tables are not displayed...
 The bug reside in the PgTableColumnsReader class, the sql statement to
 retreive all the columns is incorrect
 I have added a where condition on i.indisprimary = 't' and it fixed the
 problem.
         "SELECT a.attnum AS ordinal_position, a.attname AS column_name"
         ",t.typname AS data_type, a.attlen AS character_maximum_length"
         ",a.atttypmod AS modifier, a.attnotnull AS notnull"
         ",a.atthasdef AS hasdefault, d.adsrc AS defaultVal"
         ",a.attnum = ANY (i.indkey) AS isprimarykey, i.indkey AS primKey,
 i.indisprimary AS indisprimary"
         " FROM pg_attribute a LEFT OUTER JOIN pg_attrdef d ON a.attrelid =
 d.adrelid"
         ", pg_type t, pg_namespace n"
         ", pg_class c LEFT OUTER JOIN pg_index i ON i.indrelid = c.oid"
         " WHERE a.attnum > 0 AND a.attrelid = c.oid"
         " AND a.atttypid = t.oid AND c.relnamespace = n.oid"
         " AND t.typname !~ '^geom'"
 '''        " AND i.indisprimary = 't'"'''        " AND c.relname = '" +
 table + "' AND n.nspname = '" + schema + "' ORDER BY a.attnum;");
Ticket URL: <http://trac.osgeo.org/fdo/ticket/344>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
