[fdo-trac] #423: ClientServices build failure with 3.3.2RC2 on 64bit linux
FDO trac_fdo at osgeo.org
Tue Nov 11 13:53:29 EST 2008
 Reporter:  warmerdam  |         Owner:  gregboone
     Type:  defect     |        Status:  new
 Priority:  minor      |     Milestone:
Component:  FDO API    |       Version:  3.3.2
 Severity:  3          |    Resolution:
 Keywords:  64bit      |   External_id:
Comment (by warmerdam):
 I will note this represents an actual problem on my system with the code
 in question which appears to process /proc/self/maps on linux to get a
 list of loaded shared libraries.  The code is:
                 unsigned int start, end;
                 if (!fgets (line, sizeof (line), f))
                         continue;
                 if (!strstr (line, " r-xp ") || !strchr (line, '/'))
                         continue;
                 sscanf (line, "%x-%x ", &start, &end);
                 if (((unsigned int) symbol) >= start && ((unsigned int)
 symbol) < end)
 But on my system /proc/self/maps looks like:
 2b9a8d4a1000-2b9a8d4a3000 rw-p 00154000 03:02 1045194
 /lib/libc-2.6.1.so
 So the start and end values really should be longs and the sscanf should
 be using %lx.  Even this somewhat better approach seems to be a bit risky
 as far as portability goes. Frankly - I'm not clear why we even need such
 esoteric functionality.
 I have patched things with:
                 unsigned long start, end;
                         continue;
                         continue;
                 sscanf (line, "%lx-%lx ", &start, &end);
                 if (((unsigned long) symbol) >= start && ((unsigned long)
 symbol) < end)
 this seems to build cleanly though I don't know how to exercise it.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/423#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
