[fdo-trac] #424: thirdparty boost build on ubuntu 64bit linux
FDO trac_fdo at osgeo.org
Tue Nov 11 14:10:34 EST 2008
 Reporter:  warmerdam               |         Owner:  gregboone
     Type:  defect                  |        Status:  new
 Priority:  minor                   |     Milestone:
Component:  FDO API                 |       Version:  3.3.2
 Severity:  3                       |    Resolution:
 Keywords:  thirdparty boost linux  |   External_id:
Comment (by warmerdam):
 When working around the bjam problem I also run into this:
 /usr/bin/ld:
 /wrk/home/warmerda/wrk/fdo/OpenSource_FDO/Thirdparty/boost/stage/lib/
 libboost_thread-mt.a(condition.o): relocation R_X86_64_32 against `a local
 symbol' can not be used when making a shared object; recompile with -fPIC
 libboost_thread-mt.a: could not read symbols: Bad value
 It would appear some sort of change is needed in how the boost libraries
 are built to include -fPIC.  I'll dig around a bit to see how this might
 be done, though "jam" and boost is not my strength.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/424#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
