[fdo-trac] #428: SQL Server Spatial Provider: Incorrect sequence to
determine coordinate system data
trac_fdo at osgeo.org
Thu Nov 13 15:14:51 EST 2008
#428: SQL Server Spatial Provider: Incorrect sequence to determine coordinate
system data
Reporter: thomasknoell | Owner: thomasknoell
Type: defect | Status: new
Priority: major | Milestone:
Component: FDO API | Version: 3.4.0
Severity: 3 | Keywords:
External_id: |
In the current version, the SQL Server Spatial provider first consults the
SQL Server 2008 coordinate system library to determine the coordinate
system for a given EPSG code and then - if the information could not be
found in the library - the extended coordinate system file. However, since
the extended coordinate system file - if present - is intended to allow a
user to overwrite predefined definitions, it needs to be consulted first.
Only if there is no entry for the defined EPSG code in the extended
coordinate system file should the SQL Server 2008 coordinate system
library be consulted.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/428>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
