[fdo-trac] #433: RDBMS Providers: Better message when try to add system schema.
FDO trac_fdo at osgeo.org
Mon Nov 24 11:02:44 EST 2008
   Reporter:  brentrobinson      |       Owner:  brentrobinson
       Type:  defect             |      Status:  new
   Priority:  minor              |   Milestone:  3.4.0
  Component:  SQLServer Spatial  |     Version:  3.4.0
   Severity:  3                  |    Keywords:  apply system schema
External_id:                     |
 When an RDBMS provider datastore has metaschema, it contains a special
 system feature schema named the same as the datastore. This system schema
 contains the datastore description.
 If the user tries to add the system schema, via FdoIApplySchema, an
 exception is throw since it already exists. However, the exception message
 is index violation message issued by the RDBMS, and not as user-friendly
 as it could be.
 For example, the message from SQL Server is:
     Cannot insert duplicate key row in object 'dbo.f_schemainfo' with
 unique
     index 'f_schemainfo_idx'.
 This ticket makes the message a bit more specific, e.g.:
     Cannot add schema mydatastore to database; it has the same name as the
     system schema
Ticket URL: <http://trac.osgeo.org/fdo/ticket/433>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
