[fdo-trac] #389: SQLite provider: executing Delete after an aborted
Select fails to COMMIT
trac_fdo at osgeo.org
Wed Sep 10 12:04:30 EDT 2008
#389: SQLite provider: executing Delete after an aborted Select fails to COMMIT
Reporter: traianstanev | Owner: traianstanev
Type: defect | Status: new
Priority: major | Milestone:
Component: SQLite Provider | Version: 3.2.0
Severity: 3 | Keywords:
External_id: |
Here is the sequence that produces the problem:
* Execute a Select
* Close the FdoFeatureReader returned by the select before the reader is
finished.
* Execute a delete command
Result: The delete fails because it cannot commit its transaction. The
reason it can't is because of a bug in the SQLite implementation of
FdoIFeatureReader::Close() -- it does not reset the SQLite execution
engine in the case of a premature call to Close().
Ticket URL: <http://trac.osgeo.org/fdo/ticket/389>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
