[fdo-trac] #346: PostGIS Defect : provider does not support views
FDO trac_fdo at osgeo.org
Tue Sep 16 12:26:28 EDT 2008
 Reporter:  bscott            |         Owner:  mloskot
     Type:  defect            |        Status:  new
 Priority:  major             |     Milestone:  3.4.0
Component:  PostGIS Provider  |       Version:  3.2.0
 Severity:  3                 |    Resolution:
 Keywords:                    |   External_id:
Comment (by mwtoews):
 I've tested linking to views using Version 3.2
 (http://www.geomapgis.com/web/geomap-group/fdo/PostGIS/2008-03-
 07/FdoPg32L.zip) in AutoCAD Map 2008.
 My findings are:
  * Views can be linked as read-only, and the view must be added in the
 geometry_columns table. This is a fine solution if you don't want to
 modify the data (does this work for Mapguide users?).
  * Editable views are not currently possible from AutoCAD Map 2008. I have
 also tested views with rules for insert and update events, which are
 editable from ODBC (i.e., MS Access), but are not through FDO (message:
 "Feature source cannot be updated").
Ticket URL: <http://trac.osgeo.org/fdo/ticket/346#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
