[fdo-trac] #394: PostGIS Defect : Describe schema fails when advanced types present
FDO trac_fdo at osgeo.org
Tue Sep 16 14:48:11 EDT 2008
   Reporter:  mwtoews           |       Owner:  mloskot
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:
  Component:  PostGIS Provider  |     Version:  3.2.3
   Severity:  2                 |    Keywords:
External_id:                    |
 I've successfully added/edited spatial data in AutoCAD Map 3D 2008 using a
 PostgreSQL schema where the columns use basic types (integer, character
 varying, etc.).
 However, if I add a column to a table in that schema (spatial or not) with
 an advanced type, such as text[], integer[], or timestamp with time zone,
 the describe schema fails completely and I cannot add or use anything. My
 error are (e.g.):
  * The '_int4' data type is not supported by PostGIS provider.
  * The 'timestamptz' data type is not supported by PostGIS provider.
 I define custom types as well (such as enums), but I dread to attempt
 anything more with the current situation.
 For "not supported" types, the data should be cast to text for FDO use
 (like ODBC), and and cast back from text to original type on
 insert/update.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/394>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
