[fdo-trac] #395: SDF: Fix filter on int64 identity properties
FDO trac_fdo at osgeo.org
Wed Sep 17 16:38:49 EDT 2008
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.4.0
  Component:  FDO API        |     Version:  3.3.1
   Severity:  2              |    Keywords:  SDF Filter Select
External_id:                 |
 Defect Scenario:
    - create an SDF file with a feature class with int64 identity property
 named ID.
    - add some features to this class were one of them has ID=5.
    - Create an FdoISelect command.
    - Create the following filter via:
         FdoFilter::Parse(L"ID = 5")
      and pass it to the FdoISelect command
    - execute the FdoISelect and do a ReadNext() the resulting
      Feature Reader
 ReadNext() returns false, meaning feature 5 was not found.
 This defect also happens when the identity property type is int16 or
 single.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/395>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
