[fdo-trac] #331: Serious bug in FdoPtr<T> copy ctor (patch attached)
FDO trac_fdo at osgeo.org
Fri Sep 19 12:24:19 EDT 2008
 Reporter:  Kosta    |         Owner:  gregboone
     Type:  defect   |        Status:  reopened
 Priority:  blocker  |     Milestone:
Component:  FDO API  |       Version:  3.3.1
 Severity:  1        |    Resolution:
 Keywords:           |   External_id:
Comment (by Kosta):
 Just a short note: to spot the affected source code lines, it should be
 enough to put the proposed additional template ctor into the private
 section of the class declaration and do a recompile...
Ticket URL: <http://trac.osgeo.org/fdo/ticket/331#comment:8>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
