[fdo-trac] #507: SQLServerSpatial: infinite loop when insert to
table with trigger.
trac_fdo at osgeo.org
Thu Apr 16 10:51:53 EDT 2009
#507: SQLServerSpatial: infinite loop when insert to table with trigger.
Reporter: brentrobinson | Owner: brentrobinson
Type: defect | Status: new
Priority: major | Milestone: 3.5.0
Component: SQLServer Spatial | Version: 3.5.0
Severity: 2 | Keywords: SQL Server 2008 SQLServerSpatial insert trigger hang infinite loop
External_id: |
An infinite loop occurs in the following situation:
- datastore has two tables, each with an autoincremented primary key
column
- Table A has a trigger that fires on row insertion. The trigger adds a
row to Table B
- The SQLServerSpatial provider adds a feature to Table A via FdoIInsert.
The SQLServerSpatial provider then hangs with an infinite loop in the SQL
Server driver (below the ODBC interface).
Ticket URL: <http://trac.osgeo.org/fdo/ticket/507>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
