[fdo-trac] #507: SQLServerSpatial: infinite loop when insert to
table with trigger.
trac_fdo at osgeo.org
Thu Apr 16 11:04:35 EDT 2009
#507: SQLServerSpatial: infinite loop when insert to table with trigger.
Reporter: brentrobinson | Owner: brentrobinson
Type: defect | Status: closed
Priority: major | Milestone: 3.5.0
Component: SQLServer Spatial | Version: 3.5.0
Severity: 2 | Resolution: fixed
Keywords: SQL Server 2008 SQLServerSpatial insert trigger hang infinite loop | External_id:
Changes (by brentrobinson):
* status: assigned => closed
* resolution: => fixed
Comment:
Revision: 4552
Author: brentrobinson
Date: 11:02:53 AM, Thursday, April 16, 2009
Message:
Ticket#507: Fixed infinite loop that occurs when inserting into a table
fires a trigger that inserts into another table. Also fixed a problem
where resulting FdoIFeatureReader was retrieving the autoincremented
column value for the other table.
The hanging problem was resolved by modifying odbcdr_execute to call
SQLMoreResults() after executing the insert statement.
The wrong autoincremented value problem was solved by using
SCOPE_IDENTITY(), instead of @@IDENTITY, to retrieve the value. @@IDENTITY
gets the last autoincremented value for the current session, so it ends up
getting the value for the row inserted by the trigger. SCOPE_IDENTITY() is
limited to the current scope or batch. To get SCOPE_IDENTITY() to work, it
had to be used in the same batch as the Table A insert statement. This was
done by the following changes:
- in odbcdr_sql(), detect whether the sql statement is an insert. If it
is, tack on a "; select SCOPE_IDENTITY()" before preparing the statement.
- in odbcdr_execute(), retrieve the results of the select, when the
statement is above insert-select batch of statements. When the statement
batch as executed, 2 results sets (one for the insert and one for the
select) are set up. SQLMoreResults() is now use to navigate to the
select's result set so the autoincremented value can be retrieved. The
value is stored in the odbcdr context.
- in odbcdr_get_gen_id(), changed the global value retrieval to get the
value from the odbcdr context instead of doing a select.
Modified :
/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/context.h
Modified :
/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/crt_cursor.c
Modified :
/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/est_cursor.c
Modified :
/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/execute.c
Modified :
/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/fre_cursor.c
Modified :
/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/get_gen_id.c
Modified :
/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/rdbi_init.c
Modified :
/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/sql.c
Modified :
/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/structs.h
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/SQLServerSpatial/SqlServerFdoInsertTest.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/SQLServerSpatial/SqlServerFdoInsertTest.h
Ticket URL: <http://trac.osgeo.org/fdo/ticket/507#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
