[fdo-trac] #394: PostGIS Defect : Describe schema fails when
advanced types present
trac_fdo at osgeo.org
Wed Apr 29 03:38:31 EDT 2009
#394: PostGIS Defect : Describe schema fails when advanced types present
Reporter: mwtoews | Owner: mloskot
Type: defect | Status: new
Priority: critical | Milestone:
Component: PostGIS Provider | Version: 3.2.3
Severity: 2 | Resolution:
Keywords: | External_id:
Comment (by mwtoews):
I wasn't suggesting that FDO needs to support advanced types, since these
often get complicated with PostgreSQL (custom types are easy to build).
Rather, I'm suggesting better support/fallback when they are present.
The suggestion I'm trying to illustrate on PostgreSQL<->FDO communication
is:
* PG->FDO: unsupported PG types are cast to text for FDO (e.g.,
myarray::text)
* FDO->PG: the text from FDO is cast back to the unsupported PG type
(e.g., "{1,2,3}"::int[])
This is nicely and seamlessly implemented in the psqlODBC driver, and I
have absolutely no problems seeing and editing all my tables with
"advanced types" in MS Access. I think all PG types (including custom and
extension types) support bidirectional customtype<->text casts, so you
could offload all type conversions to PG without much effort from FDO. All
that needs to be done by FDO is to manage the casting to/from text for
unsupported types on insert/select/update operations.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/394#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
