[fdo-trac] #550: SQL Spatial - poor error message when trying to
insert into a table without a primary key
trac_fdo at osgeo.org
Fri Aug 21 11:58:08 EDT 2009
#550: SQL Spatial - poor error message when trying to insert into a table without
a primary key
Reporter: chriserickson | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone: 3.5.0
Component: FDO API | Version: 3.4.0
Severity: 3 | Keywords:
External_id: |
I have created a basic table in SQL 2008, with 3 fields: ID (char[36]),
Shape (Geometry), Description (varchar(255).
When I try and insert data, I’m getting an error: “Creating/Updating a
standalone instance for class 'TestGeometry' is not allowed.”
Here is a snippet of when it is happening:
IInsert insertCommand =
(IInsert)_database._connection.CreateCommand(CommandType.CommandType_Insert);
insertCommand.SetFeatureClassName(_class.QualifiedName);
<- happens on this line.
It turns out this is caused by the table not having a primary key set.
The error message is not helpful in discerning the cause of the error.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/550>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
