[fdo-trac] #551: ArcSDE Provider: Port to ArcSDE 9.3.1
FDO trac_fdo at osgeo.org
Mon Aug 24 11:09:58 EDT 2009
 Reporter:  brentrobinson    |         Owner:  brentrobinson
     Type:  enhancement      |        Status:  assigned
 Priority:  major            |     Milestone:  3.5.0
Component:  ArcSDE Provider  |       Version:  3.5.0
 Severity:  2                |    Resolution:
 Keywords:  ArcSDE 9.3.1     |   External_id:
Changes (by brentrobinson):
  * status:  new => assigned
Comment:
 Revision: 4895
 Author: brentrobinson
 Date: 11:05:32 AM, Monday, August 24, 2009
 Message:
 Ticket#551: TModifies the ArcSDE provider (windows 32bit) to work with
 ArcSDE 9.3 (particularly 9.3.1).
 ArcSdeCreateSpatialContext - set auth_srid for new spatial contexts.
 ArcSDE 9.3 ignores auth_name when auth_srid is not set. auth_name is where
 the spatial context name is stored.
 ArcSdeUtils::convert_fgf_to_sde_shape - duplicate coordref, for geometry,
 from geometry column. This ensures that the geometry has the same
 coordinate system as its column.
 Modified :
 /trunk/Providers/ArcSDE/Src/Provider/ArcSDECreateSpatialContext.cpp
 Modified : /trunk/Providers/ArcSDE/Src/Provider/ArcSDEUtils.cpp
 Modified : /trunk/Providers/ArcSDE/Src/UnitTest/BasicInsertTests.cpp
 Modified : /trunk/Providers/ArcSDE/Src/UnitTest/ExpressionFunction.cpp
 Modified : /trunk/Providers/ArcSDE/Src/UnitTest/ExpressionFunction.h
 Modified : /trunk/Utilities/TestCommon/Inc/TestCommonExpressionFunction.h
 Modified : /trunk/Utilities/TestCommon/Inc/TestCommonExpressionFunctionW.h
 Modified :
 /trunk/Utilities/TestCommon/Src/TestCommonExpressionFunction.cpp
 Modified :
 /trunk/Utilities/TestCommon/Src/TestCommonExpressionFunctionW.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/551#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
