[fdo-trac] #454: Insert commands seriously messed up when null
values are omitted
trac_fdo at osgeo.org
Wed Feb 4 11:14:02 EST 2009
#454: Insert commands seriously messed up when null values are omitted
Reporter: jng | Owner: traianstanev
Type: defect | Status: assigned
Priority: critical | Milestone: 3.4.0
Component: SQLite Provider | Version: 3.4.0
Severity: 1 | Resolution:
Keywords: | External_id:
Comment (by traianstanev):
Here are more details on the problem... If you change the contents of the
property value collection of the insert command, after having executed the
insert command once, you are asking for trouble, because the provider
caches a pre-compiled parametrized SQL statement based on the state of the
property value collection during the first time you Execute(). Note that
you can change the actual values, just not the set of property values in
the collection. The two workarounds described in the previous note will
avoid that problem.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/454#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
