[fdo-trac] #463: DotNet DLLS should have unmanaged dlls marked as
DELAYLOAD
trac_fdo at osgeo.org
Thu Feb 19 11:41:36 EST 2009
#463: DotNet DLLS should have unmanaged dlls marked as DELAYLOAD
Reporter: chriserickson | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone:
Component: FDO API | Version: 3.4.0
Severity: 2 | Keywords:
External_id: |
When attempting to use FDO 3.4 in a web-service environment, we are having
to install the unmanaged FDO dlls onto the system path. This can corrupt
installations where the user has a different application with a different
version of FDO installed.
To resolve this issue, we can modify the web application's path after it
is loaded, but must have the unmanaged dlls marked as 'delayload' in the
managed dlls. This needs to be done on MgCommon, MgFDO, MgGeometry, and
MgSpatial. To do so, open up the project properties on each of these,
navigate to the Configuration Properties\Linker\Input secion, and specify
each of the dependancies (i.e. FDOCommon.dll on FDO.Common) in the 'Delay
Loaded DLLs' section.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/463>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
