[fdo-trac] #582: FdoExpressionEngineUtilFeatureReader returns a class definition that does not contains the computed fields
FDO trac_fdo at osgeo.org
Wed Nov 11 05:29:33 EST 2009
   Reporter:  Aleck    |       Owner:  gregboone
       Type:  defect   |      Status:  new
   Priority:  major    |   Milestone:  3.5.0
  Component:  FDO API  |     Version:  3.4.0
   Severity:  3        |    Keywords:
External_id:           |
 When we select computed fields through FDO, a
 !FdoExpressionEngineUtilFeatureReader may be returned if the expression in
 not supported by the underlying database. However if you acquire the class
 definition from !FdoExpressionEngineUtilFeatureReader, the computed fields
 are not in it. Which is wrong
 This fix adds code to clone a class definition containing the computed
 fields when
 constructing the !FdoExpressionEngineUtilFeatureReader.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/582>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
