[fdo-trac] #589: SQLServerSpatial does not support same table in 2 schemas.
FDO trac_fdo at osgeo.org
Thu Nov 19 15:30:04 EST 2009
   Reporter:  chriserickson  |       Owner:  gregboone
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.5.0
  Component:  FDO API        |     Version:  3.4.0
   Severity:  3              |    Keywords:
External_id:                 |
 I have a database with a layer (Parcels) which exists in 2 schemas.
 On a select command, when you call SetFeatureClassName and hand in the
 class's qualified name, it hands in an (unqualified) name of 'Parcels'.
 An error is then thrown "class parcels found in multiple schemas".
 There is no workaround that I've found, I've tried setting my default
 schema in SQL and handing an a fully qualified name ("Schema.Parcels"),
 which then just throws an error that it could not find the layer.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/589>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
