[fdo-trac] #571: Fix FDO IoTest unit test to work with piped streams.
trac_fdo at osgeo.org
Fri Oct 23 08:06:02 EDT 2009
Reporter: brentrobinson | Owner: brentrobinson
Type: defect | Status: new
Priority: major | Milestone: 3.5.0
Component: General | Version: 3.4.0
Severity: 3 | Keywords: FdoIoFileStream pipe unit test
External_id: |
If the FDO unit tests are run by the following steps:
* cd Fdo\Unmanaged\bin\win32\debug
* echo "hello" | unittest FdoIoTest
then TestFileCapabilities fails on the assertion "stream->HasContext() ==
true".
The reason is that FdoIoFileStream reports that stdin does not have
context (it is on a pipe in this case), but the unit test expects it to
have context.
FdoIoFileStream is working correctly. Although functions, such as ftell
and fseek, work successfully on pipes, pipes are not contextual. fseek
will succeed but the current file pointer will not actually move.
Therefore, the fix will be to correct the unit test.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/571>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
