[fdo-trac] #562: Problem with wchar in Linux
trac_fdo at osgeo.org
Fri Sep 25 15:39:58 EDT 2009
Reporter: rafael | Owner: haris
Type: defect | Status: new
Priority: major | Milestone: 3.5.0
Component: KingOracle Provider | Version: 3.4.0
Severity: 2 | Keywords:
External_id: |
Unlike Windows UTF-16 2-byte wide chars, wchar_t on Linux and OS X is 4
bytes UTF-32 (gcc/g++ and XCode).
Code like this don’t work in Linux:
Oracle manual:
“To prepare the SQL statement, call OCIStmtPrepare with (utext*) string.
The following example runs on Windows platforms only. You may need to
change wchar_t datatypes for other platforms.
const wchar_t sqlstr[] = L"SELECT * FROM ENAME=:ename";
OCIStmt* stmthp;
sts = OCIHandleAlloc(envh, (void **)&stmthp, OCI_HTYPE_STMT, 0, NULL);
status = OCIStmtPrepare(stmthp, errhp,(const text*)sqlstr, wcslen(sqlstr),
OCI_NTV_SYNTAX, OCI_DEFAULT);
Ticket URL: <http://trac.osgeo.org/fdo/ticket/562>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
