[fdo-trac] #637: Can't get the PropertyName against the Sql Server Spatial
FDO trac_fdo at osgeo.org
Thu Apr 8 01:30:07 EDT 2010
 Reporter:  hubu               |         Owner:  hubu
     Type:  defect             |        Status:  new
 Priority:  blocker            |     Milestone:  3.5.0
Component:  SQLServer Spatial  |       Version:  3.5.0
 Severity:  2                  |    Resolution:
 Keywords:                     |   External_id:  1291809
Comment (by hubu):
 [Problem]:
 In MapGuide Studio, when connect to SQLSERVER Spatial, and preview the
 features in the feature editor, we will get a fdo exception "Invalid
 Stream Header". This problem only happens on Sqlserver spatial provider.
 [Reason]:
 In the FdoRdbmsDataReader, the GetPropertyName functon is defined like
 this:
     virtual FdoString* GetPropertyName(FdoInt32 index)
         EXECUTE_METHOD(GetPropertyNameForDataReader( index ));
 When the FdoRdbmsDataReader::GetPropertyName() is invoked, actually the
 FDORbmbsFeatureReader::GetPropertyNameForDataReader() will be executed.
 And the FDORbmbsFeatureReader::GetPropertyNameForDataReader() is a virtual
 mothod.
 The FdoRdbmsSqlServerOptimizedAggregateReader derived from
 FdoRdbmsFeatureReader.  The problem is
 FdoRdbmsSqlServerOptimizedAggregateReader doesn't override the
 GetPropertyNameForDataReader(FdoInt32 index) mothod.
 In this case, the FDORbmbsFeatureReader::GetPropertyNameForDataReader() is
 executed instead of the
 FdoRdbmsSqlServerOptimizedAggregateReader::GetPropertyNameForDataReader().
 The method FDORbmbsFeatureReader::GetPropertyNameForDataReader() will
 invoke the FDORbmbsFeatureReader::GetPropertyCount() mothod to initialize
 the array mColList before using this array. But the
 FDORbmbsFeatureReader::GetPropertyCount() is overrided by the
 FdoRdbmsSqlServerOptimizedAggregateReader::GetPropertyCount(), in this
 override function, the mColList is not initialized. Then the execption
 happens when read the uninitialized array mColList.
 [Solution]:
 Override the GetPropertyNameForDataReader(FdoInt32 index) mothod in the
 FdoRdbmsSqlServerOptimizedAggregateReader.
 TESTING PERFORMED:
 Make sure the SQL Server spatial feature preview successfully.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/637#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
