[fdo-trac] #674: Create FDO connection directly from library name.
FDO trac_fdo at osgeo.org
Fri Aug 6 14:24:56 EDT 2010
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  enhancement    |      Status:  new
   Priority:  minor          |   Milestone:  3.6.0
  Component:  FDO API        |     Version:
   Severity:  3              |    Keywords:  Connection Manager Provider Library
External_id:                 |
 Under this enhancement, more flexibility will be added to the
 FdoIConnectionManager::CreateConnection() function, by allowing the
 providerName parameter to be a provider library file name or a registered
 provider name. Currently, providerName must be the name of a registered
 provider.
 When providerName is set to a library, FDO will load the library and
 obtain the FDO connection from it.
 This enhancement adds some convenience for applications that want to use a
 provider that is not registered. As long as the application knows the
 provider's library file name, it will be able to obtain a connection from
 the provider.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/674>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
