[fdo-trac] #437: Georaster Oracle 11g support in FDO
trac_fdo at osgeo.org
Thu Aug 12 15:40:15 EDT 2010
Reporter: ssddgreg | Owner: gregboone
Type: enhancement | Status: new
Priority: minor | Milestone:
Component: FDO API | Version:
Severity: 5 (Wish List) | Keywords:
External_id: |
Changes (by ilucena):
* cc: ilucena (added)
Comment:
The KingOracle data provider does not support Oracle GeoRaster as I can
see from here:
[http://trac.osgeo.org/fdo/browser/trunk/Providers/KingOracle/src/Provider/c_KgOraRasterCapabilities.cpp#L33]
But I believe you can access GeoRaster on FDO through the GDAL data
provider, as long as you have compiled GDAL with Oracle support or if you
have a GDAL plugin for GeoRaster installed (on Windows that will be
"gdal_GEOR.dll" or linux, "gdal_GEOR.so").
If you have that, you can read a GeoRaster by passing the GDAL/GeoRaster
identification string and you can write the same way (if you can pass
create-options to the GDAL driver, that will work better).
More about GDAL and GeoRaster: [http://www.gdal.org/frmt_georaster.html]
Ticket URL: <http://trac.osgeo.org/fdo/ticket/437#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
