[fdo-trac] #613: SDF: Handle read-only files and default values
trac_fdo at osgeo.org
Thu Feb 11 10:05:55 EST 2010
Reporter: romicadascalescu | Owner: romicadascalescu
Type: defect | Status: new
Priority: major | Milestone: 3.5.0
Component: SDF Provider | Version: 3.5.0
Severity: 4 | Keywords:
External_id: |
- Handle read-only files: in case we connect to a read only file avoid
altering
READONLY connection flag.
- Make consistent default read-only flag (was false) from the connection
with
read-only flag from connection parameter (was true). I've made them all
false.
- Handle default values, by setting values to the property in case the
property
is not set and it has a default value provider will set the default value.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/613>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
