[fdo-trac] #614: WMS: Provider uses invalid EXCEPTIONS parameter
when querying version 1.3.0 WMS Servers
trac_fdo at osgeo.org
Thu Feb 11 13:41:01 EST 2010
#614: WMS: Provider uses invalid EXCEPTIONS parameter when querying version 1.3.0
WMS Servers
Reporter: gregboone | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone: 3.6.0
Component: FDO API | Version: 3.5.0
Severity: 2 | Keywords:
External_id: 1300502 |
Scenario:
Connect to: <http://www2.dmsolutions.ca/cgi-bin/mswms_gmap> [[BR]]
Select and draw Layer: Drainage
Error:
There was a problem adding data. [[BR]]
!InvalidFormat: msWMSLoadGetMapParams(): WMS server error. [[BR]]
Invalid format for the EXCEPTION parameter. [[BR]]
Analysis:
The WMS !GetMap specification changed between versions 1.1.1 and 1.3.0,
and the keywords used to specifiy the EXCEPTIONS format changed. However,
the WMS provider continues to use the 1.1.1 keywords for both 1.1.1 and
1.3.0 requests.
Solution:
Based on the version of the WMS server, use the correct EXCEPTIONS
keywords when making !GetMap requests.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/614>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
