[fdo-trac] #606: SDF: Insert feature would lose default value if that property is readonly
FDO trac_fdo at osgeo.org
Wed Jan 20 22:07:10 EST 2010
   Reporter:  lind          |       Owner:  lind
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.5.0
  Component:  SDF Provider  |     Version:  3.4.0
   Severity:  3             |    Keywords:
External_id:  1293087       |
 SDF Provider will not setting the defaut value of a property is that
 property is readonly.
 In Autocad Map3D when creating a SDF with a property with default value
 and readonly is true, then the features in this SDF created will lost the
 default values. And also, bulk copy makes the target SDF lost the default
 values even the sources are correct.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/606>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
