[fdo-trac] #610: PostgreSQL views have no attributes in FDO 3.4.1
FDO trac_fdo at osgeo.org
Mon Jan 25 18:27:33 EST 2010
   Reporter:  mwtoews           |       Owner:
       Type:  defect            |      Status:  new
   Priority:  critical          |   Milestone:  3.5.0
  Component:  PostGIS Provider  |     Version:  3.4.0
   Severity:  2                 |    Keywords:
External_id:                    |
 AutoCAD Map 3D 2008 has the ability to use PostGIS views with attributes
 (for labels or query filters) using the FDO 3.2 provider from
 [http://www.geomapgis.com/web/geomap-group/fdo/index.html GEOMAP]
 However, this doesn't work with AutoCAD Map 3D 2010 with FDO 3.4.x. With
 version 3.4.0, the behaviour is that the database views are not listed as
 an available sources in the "Add Data" dialog (only tables are shown).
 With version [http://download.osgeo.org/fdo/3.4.1/binaries/ 3.4.1] and
 from GEOMAP, the database views are listed, and correctly show feature
 data on the map, however there are no attributes for the features. When a
 table is shown for the layer, there is only 1 blank column with all <NULL>
 values for each feature (see attached).
Ticket URL: <http://trac.osgeo.org/fdo/ticket/610>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
