[fdo-trac] #668: Deep copy of schema with many association properties fails.
FDO trac_fdo at osgeo.org
Thu Jul 22 16:02:40 EDT 2010
 Reporter:  brentrobinson                   |         Owner:  brentrobinson
     Type:  defect                          |        Status:  closed
 Priority:  minor                           |     Milestone:  3.6.0
Component:  FDO API                         |       Version:
 Severity:  3                               |    Resolution:  fixed
 Keywords:  Association Property deep copy  |   External_id:
Changes (by brentrobinson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Revision: 5566
 Author: brentrobinson
 Date: 4:01:52 PM, Thursday, July 22, 2010
 Message:
 Ticket#668:
 FdoAssociationPropertyDefinition - update readonly association property
 after identity or reverse identity properties have changed.
 FdoCommonSchemaUtil - when deep copying a class definition, copy data
 properties before base class, object properties, or association
 properties. This ensures that the class data properties are all present if
 the class is recursively revisited.
 FdoExpressionUtilFeatureReader - implemented GetFeatureObject()
 Modified :
 /trunk/Fdo/Unmanaged/Src/Fdo/Schema/AssociationPropertyDefinition.cpp
 Modified : /trunk/Utilities/Common/Inc/FdoCommonSchemaUtil.h
 Modified : /trunk/Utilities/Common/Src/FdoCommonSchemaUtil.cpp
 Modified :
 /trunk/Utilities/ExpressionEngine/Src/Util/FdoExpressionEngineUtilFeatureReader.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/668#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
