[fdo-trac] #654: GDAL FDO does not handle rotate images
    trac_fdo at osgeo.org
    Tue Jun  8 10:13:25 EDT 2010
   Reporter:  andrewd        |       Owner:  warmerdam
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.6.0
  Component:  GDAL Provider  |     Version:  3.4.0
   Severity:  3              |    Keywords:
External_id:                 |
 I'm using Mapguide and the GDAL FDO (been dealing with this problem since
 MGOS v1.2). If an georeferenced image needs rotation (*any* amount of
 rotation at all), the image is displayed incorrectly (ie, without the
 rotation). If the GDAL provider can now handle reprojection, then there's
 absolutely no reason why it still can't handle rotation. It's a serious
 problem, when you've got air photo flight lines that don't run exactly
 west to east. Is there a workaround or a fix out there that I don't know
 about?
Ticket URL: <http://trac.osgeo.org/fdo/ticket/654>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
