[fdo-trac] #548: SQL Spatial 'DataStore' connection property is case sensitive
FDO trac_fdo at osgeo.org
Mon Mar 1 16:36:04 EST 2010
 Reporter:  chriserickson  |         Owner:  gregboone
     Type:  defect         |        Status:  new
 Priority:  major          |     Milestone:  3.5.0
Component:  FDO API        |       Version:  3.4.0
 Severity:  3              |    Resolution:
 Keywords:                 |   External_id:
Comment (by brentrobinson):
 It is possible for SQL Server to be case-sensitive. It is case-insensitive
 by default but, if a case-sensitive collation is chosen when the server is
 installed, then it will be case-sensitive. However, there is still a
 defect in that the error message needs to be much more informative.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/548#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
