[fdo-trac] #635: FdoDataValue: error converting max + 1
trac_fdo at osgeo.org
Wed Mar 31 16:39:32 EDT 2010
Reporter: brentrobinson | Owner: brentrobinson
Type: defect | Status: closed
Priority: major | Milestone: 3.6.0
Component: FDO API | Version: 3.5.0
Severity: 2 | Resolution: fixed
Keywords: DataValue convert precision | External_id:
Changes (by brentrobinson):
* status: new => closed
* resolution: => fixed
Comment:
Revision: 5446
Author: brentrobinson
Date: 2:57:08 PM, Wednesday, March 31, 2010
Message:
Ticket#635: Handle floating point to integral conversion where floating
point value = max + 1, where max is the maximum value for the output type.
Modified : /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DataValue.h
Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp
Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp
Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp
Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp
Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/635#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
