[fdo-trac] #642: Sqlite filtering on number with more that 5 decimal fails
FDO trac_fdo at osgeo.org
Wed May 5 10:33:56 EDT 2010
 Reporter:  bscott           |         Owner:  traianstanev
     Type:  defect           |        Status:  new
 Priority:  major            |     Milestone:  3.5.0
Component:  SQLite Provider  |       Version:  3.5.0
 Severity:  3                |    Resolution:
 Keywords:                   |   External_id:
Comment (by bscott):
 The same query works find when executed out of FDO.
 If i run "select * from table where column = 1.000001" in a native SQLIte
 engine it works fine.
 By the way > , < , >= , <= have the same bug.
 Really likely that the String/Double truncation is in the provider
Ticket URL: <http://trac.osgeo.org/fdo/ticket/642#comment:4>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
