[fdo-trac] #641: SQLite Can't create a datetime column
trac_fdo at osgeo.org
Wed May 5 11:11:22 EDT 2010
Reporter: bscott | Owner: traianstanev
Type: defect | Status: new
Priority: blocker | Milestone: 3.5.0
Component: SQLite Provider | Version: 3.5.0
Severity: 1 | Resolution:
Keywords: | External_id:
Comment (by bscott):
I know that option would work
but it's not a solution for us.
I want my clients to be able to manage there database with standard
SqlLite tools.
When using UseFdoMetadata=TRUE it create a bunch of fdo metadata tables
that make database
administration a nightmare.
Even if we have a AutoCAD Map to edit the SqlLite schema, it's pretty
difficult to use views as source of data for a featureclass
As quoted in the http://www.sqlite.org/datatypes.html document
"Even though SQLite allows the datatype to be omitted, it is still a good
idea to include it in your CREATE TABLE statements, since the data type
often serves as a good hint to other programmers about what you intend to
put in the column"
So even if you store the date as string internally, it should not be very
difficult to include DATE or TIMESTAMP in the CREATE TABLE statement
Ticket URL: <http://trac.osgeo.org/fdo/ticket/641#comment:5>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
