[fdo-trac] #641: SQLite Can't create a datetime column
FDO trac_fdo at osgeo.org
Thu May 6 03:13:37 EDT 2010
 Reporter:  bscott           |         Owner:  traianstanev
     Type:  enhancement      |        Status:  assigned
 Priority:  blocker          |     Milestone:  3.5.0
Component:  SQLite Provider  |       Version:  3.5.0
 Severity:  1                |    Resolution:
 Keywords:                   |   External_id:
Comment (by bscott):
 I've made a try with UseFdoMetadata=TRUE
 and with fdo_columns table well populated.
 So when using FdoIFeatureReader and FdoIDataReader ( for simple query )
 everything works well,a describe on the table returns a datetime type.
 For Complex Query ( on multiple tables with joins ) using
 FdoISQLDataReader
 I still have the date as string problem
 Now just imagine an application with more than 200 tables and 50 views.
 This is a common situation for our client.
 Maintaining the fdo_columns table is lot of overhead and will make sqlite
 less attractive
Ticket URL: <http://trac.osgeo.org/fdo/ticket/641#comment:8>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
