[fdo-trac] #641: SQLite Can't create a datetime column
FDO trac_fdo at osgeo.org
Thu May 6 12:47:23 EDT 2010
 Reporter:  bscott           |         Owner:  traianstanev
     Type:  enhancement      |        Status:  assigned
 Priority:  blocker          |     Milestone:  3.5.0
Component:  SQLite Provider  |       Version:  3.5.0
 Severity:  1                |    Resolution:
 Keywords:                   |   External_id:
Comment (by romicadascalescu):
 I hope you are using the provider from trunk (3.6), which has below
 improvements (view update, and a few other), versions are API compatible.
 Also having 500 up classes (tables + views) I would really advice you to
 avoid all the time calling describe schema for the full schema. Lately in
 the provider I added support in Describe schema to get only definition for
 certain class/classes, see
 FdoIDescribeSchema::SetClassNames(FdoStringCollection* value);
 As Traian said we do have databases with 600+ class 50+ views and 1200
 indexes :) so we had to fix some issues also.
 The speed difference between having fdo_columns and not is not huge.
 Regards,
 Romy.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/641#comment:11>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
