[fdo-trac] #644: Sqlite filtering on date returns wrong results
FDO trac_fdo at osgeo.org
Fri May 7 02:56:59 EDT 2010
   Reporter:  bscott           |       Owner:  traianstanev
       Type:  defect           |      Status:  new
   Priority:  major            |   Milestone:  3.5.0
  Component:  SQLite Provider  |     Version:  3.5.0
   Severity:  3                |    Keywords:
External_id:                   |
 Running our internal unit test i found some errors on date filtering.
 Our Unit test are runned against many FDO providers
   SHP
   SDF
   Autodesk.Oracle
   King.Oracle
   MySQL
   SqlServer
 Our UnitTest returns the same result on date filtering except for Sqllite
 Tested on FeatureClass and Class
 Table POINT structure
         KEY_1   INTEGER
         DATE_1  TEXT
 with fdo_columns.fdo_data_type = 2
 Table POINT data
 KEY_1   DATE_1
 1       2007-01-01T00:00:00.000
 2       2007-01-02T00:00:00.000
 99      2007-04-09T00:00:00.000
 100     2007-04-10T00:00:00.000
 Unit test Date and timestamp filter
 Select KEY_1 from POINT where DATE_1 = DATE '2007-01-01'
   failed
   returns nothing
   should return 1
 Select KEY_1 from POINT where DATE_1 is null
   ok
 Select KEY_1 from POINT where DATE_1 is not null
   ok
 Select KEY_1 from POINT where DATE_1 > DATE '2007-04-09'
   failed
   returns 99,100
   should only return 100
 Select KEY_1 from POINT where DATE_1 >= DATE '2007-04-09'
   ok
 Select KEY_1 from POINT where DATE_1 < DATE '2007-01-02'
   ok
 Select KEY_1 from POINT where DATE_1 <= DATE '2007-01-02'
   failed
   return 1,2
 Select KEY_1 from POINT where DATE_1 = TIMESTAMP '2007-01-01 00:00:00'  ok
 Select KEY_1 from POINT where DATE_1 > TIMESTAMP '2007-04-09 00:00:00'  ok
 Select KEY_1 from POINT where DATE_1 >= TIMESTAMP '2007-04-09 00:00:00' ok
 Select KEY_1 from POINT where DATE_1 < TIMESTAMP '2007-01-02 00:00:00'  ok
 Select KEY_1 from POINT where DATE_1 <= TIMESTAMP '2007-01-02 00:00:00' ok
 I have attached our unittest sqlite database on the ticket
Ticket URL: <http://trac.osgeo.org/fdo/ticket/644>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
