[fdo-trac] #644: Sqlite filtering on date returns wrong results
trac_fdo at osgeo.org
Fri May 7 03:05:08 EDT 2010
Reporter: bscott | Owner: traianstanev
Type: defect | Status: new
Priority: major | Milestone: 3.5.0
Component: SQLite Provider | Version: 3.5.0
Severity: 3 | Resolution:
Keywords: | External_id:
Comment (by bscott):
Still got problem formating text in trac :(
All test using TIMESTAMP works fine :
Select KEY_1 from POINT where DATE_1 = TIMESTAMP '2007-01-01 00:00:00'
ok
Select KEY_1 from POINT where DATE_1 > TIMESTAMP '2007-04-09 00:00:00'
ok
Select KEY_1 from POINT where DATE_1 >= TIMESTAMP '2007-04-09 00:00:00'
ok
Select KEY_1 from POINT where DATE_1 < TIMESTAMP '2007-01-02 00:00:00'
ok
Select KEY_1 from POINT where DATE_1 <= TIMESTAMP '2007-01-02 00:00:00'
ok
Ticket URL: <http://trac.osgeo.org/fdo/ticket/644#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
